Just joined TDR after I recently bought my first CTD, an '03 SLT 2500 Quad Cab and so far, this is a great resource.
OK, so I have been running AMSOIL 15-40 for the past two oil changes and decided to try their bypass system for '03 and older trucks (BMK-15Ea). This system is a dual remote filter with one bypass and one full flow using a spin on adapter where the existing full flow filter was.
Well, I got the system installed and plumed, spent extra time checking my hose routing and ensuring a secure installation. I filled both filters, topped up the crankcase and immediately upon start-up I had a whine/drone from the engine noticeable mostly from the vacinity of the passenger side floorboard. I didn't spend much time with it running, as i really don't know what this is. Could excessive backpressure in the system from the additional filter cause the oil pump to cavitate?? There are no other symptoms, the engine ran fine with normal oil pressure. As you can imagine, I am extremely concerned and would appreciate any help you can offer. At this point, since I use the truck extensively for work, I think I will be removing the system tomorrow and hope that no dammage has been done!!??
