Amsoil Change Interval
White Smoke Fix
1989 HELP
Looking for oil change interval suggestions. Just went Amsoil in engine. Getting mixed signals from everyone as to change interval. Supplier tells me to go 10K, change filter and go 10K more... seems like alot.
93 ClubCab LE 250, 4X4,K&N,Amsoil/Mobil Synthetics
4" Chrome stack,BFG 315/75R 16's, American Eagles
118K, 10K-GVW Springs w/GN hitch. 12cm/2 30 psi
From what I have been reading. It is the best to have your oil tested. This is the truest way to determine if it is failing or not. I have seen where some people have been going 20K or more for miles but only changing the Oil Filter every 7K - 10K and replacing only 1 quart of oil. I have not switched to Amsoil for oil yet but have it in the rear end. Some day... some time I will. The bypass is the way to go. Makes it that much cleaner and last that much longer before changing.
Scott
92 Ram, Bright White, Club Cab, LE package, 4x4, 130K, 3. 54 gears, Auto, Extra transmission Cooler, 285x75x16 Cooper Discovery A/T, 16X10 American Racing rims, RS9000, Tekonsha, Running boards, Lund Sunvisor & bug shield, Marker lights, Tonneau cover, Full cap, DynoMax, 5" Chrome tip, 16 cm Turbo, Isspro Boost, 23 lbs Boost empty, Oil Pressure Gauge, Pump Adj, Sprayed in Bed-liner, Rubber mat
'SHAKES, RATTLES & GOES'
Nuttymopar, This is true with the by-pass filter, my 1994 cummins had 11,700/8 months on the oil with remarks from oil analysis of "suitable for continued use". The lab will let you know when to change filters and when to change oil. The by-pass filter will filter the oil down to less than than 1 micron. My 94 was totaled in a head-on collision in Oct. I now have a 1995 with the by-pass system from my 94. I have put 8K on this oil (15w40 heavy duty diesel and marine oil) and will pull a sample at 12K. Hope this helps.
1995 2500, SLT Laramie, Xcab, auto, 3. 54, stock plate forward, Amsoiled throughout, dual by-pass filter, muffler and cat fell off, if you find them, there yours!!
Just got my last oil analysis back 2 weeks ago. Says oil is fine for continued use. I change the filter and add quart of oil every 5K miles. My latest sample was pulled at 21K miles. I had been using AMSOIL oil filters and K&N air filter. I'm gonna go for one more sample at about 25K miles and change it all out then.
'95, 2500, 4X4, ext cab, white, 3. 54 rear end, auto transmission
Griffin Radiator, Banks Power Pak, Kondolay TC, Kondolay VB, 16cm Turbo, 4" exhaust, Horton Fan, Bosch 215, BD Governor Springs, Brite Box, Mag Hytec transmission Pan, aux transmission Cooler, Bully Dog Propane, Gutless Kitty, Wiley Coyote strapped to my grill
Hey guys, I am new on the site but not new to Amsoil and their system. I ran Castrol syntec for the first 60k then went to the bypass system and Amsoil. I started changing the bypass filters at 10k and then both at another 10k. Then I went up to 20k. I changed all the oil at 50K. My samples said I could continue, but I figured I got my $ worth on 50k. I have got 40k on the second change and will send a sample and change the filters. I use the marine 15w-40. I am sold on the system. I have 150k of stop and go in town driving on my service truck(very hard on a desiel). I had to have my transmission overhauled at 125k because the seperator plate was worn thru in 3 places by the steel balls because of shiffting!I would not use any other oil but Amsoil.
[This message has been edited by fastmark (edited 02-07-2001). ]
There are 2 types, the by-pass oil filter (which tapes into the oil system at the oil sending unit) and the dual by-pass oil filter. I use the dual by-pass oil filter. It comes with all the hardware needed to install on the Cummins including the SDF filter and the by-pass filter. Your oil filter is removed and replaced with the dual by-pass kit. This kit allows you to mount your filters in an area that is easy to get to and contains both filters side by side. The Amsoil by-pass filter removes particles as small as 1/10 of a micron, virtually eliminating engine wear. If you need more info, email me.
1995 2500, SLT Laramie, Xcab, auto, 3. 54, stock plate forward, Amsoiled throughout, dual by-pass filter, Amsoil Dealer, muffler and cat fell off, if you find them, there yours!!
