Since it was asked on this forum to post the specs for this oil, I thought I would do just that.
APPLICATION
Amsoil Synthetic HD Diesel and Marine motor oil is designed to meet or exceed the following engine requirements.
API Engine service CH-4,CG-4,CF-2,CF,SH,SJ
MIL-L2104G,MIL-L21260D*(*Rust protection & neutralization tests)
Caterpillar TO-2,TO-3
Allison C-3,C-4
Mack EO-L,EO-L Plus,EO-M
Mercedes-Benz AG 227. 1,228. 1,228. 3
Scania Long Drain
Volvo VDS,VDS-2
VW 505. 00
Cummins CFS 20071,20072
MTU
Kinematic Viscosity @ 100 C,cST. . 15. 0
Kinematic Viscosity @ 40 C,cST . . 91. 2
Viscosity Index(ASTM D-2270) . . 172
CCS Viscosity @-15 C,cP(ASTM D-2602) 2350
Pour Point C(F). . (ATSM D-97) -44 (-47)
Flash Point C (F). . (ASTM D-92) 228 (442)
Four Ball Wear Test(ASTM D-4172B:40kg,75 C
1200 RPM 1 hr). . Scar,mm 0. 35mm
Noak Volitility, % weight loss. . (g/100g 6. 0
High temp/High Shear Viscosity(ASTM D-4683)
cP,150 C, 1. 0 x 10 6th power-1... . >3. 7
TOTAL BASE NUMBER... 12
There you have it.
Wayne
amsoilman
94'SLT 4X4 AT/White in color. Factory Tow Hooks & Running Boards. Amsoil By-Pass filter, Amsoil Air cleaner,and all fluids are Amsoil. Optima "Red Top" batteries.
BD exhaust Brake, BD Torque Lock, BD Torque Converter, Dr. Performance Stage II Injection Pump. Mag-Hytec Diff Cover,Mag-Hytec Transmission Pan, Isspro Pyro, Boost,Oil temp Gauges mounted in 3 Gauge post mount. One gauge monitors Engine Oil, Trans, Diff. Temps.
APPLICATION
Allison C-3,C-4
Scania Long Drain
Volvo VDS,VDS-2
VW 505. 00
MTU
There you have it.
Wayne
amsoilman
