If I might mention, there are more than that Amsoil by pass systems out there. In fact you can fab your own with parts from the scrap metal bin and parts stores like NAPA. Google diesel engines oil bypass systems and you'll find many ideas, designs and with pictures and parts numbers.
When I first installed mine, I wanted to wait until I had a full oil change out before I installed the Amsoil filter, so I installed a Donaldson ELF filter (like I use for my main filter) to see what would happen. The bypass system is designed with a restriction in it and a hole drilled to act as an orfice allowing less than 10% of the total downstream flow from your main filter discharge to be bypassed. This way the flow is so small it gives the filter a real chance to filter the oil and collect the trash, and with the discharge of the bypass going back into your engine, never starves the engine. I's like to mention, even if your bypass filter plugs, all it will do is have the total oil volume route the same as without a bypass, until your put a new filter on again. So your truck is protected.
I sent a sample to Blackstone to see the difference from the prior oil change, and even with the Donaldson ELF as a bypass filter, it was a very improved sample. Yes, the Amsoil 2 micron filter will do much better, but if your not wanting to pay the price, there are alternatives. I use the an Amsoil by choice, for now.
Pre-made or homemade, they should install bypasses at the manufactures assembly line. They use to decades ago.
