Amsoil products
ALMOST legal...
10 wt oil additive
Not looking to start a product war... ... ... ..... but I'm looking for the recemmended air filter and diff oil prducts available from Amsoil.
Want to hear from members who have used the products who can provide part numbers.
Thanks,
Ron
This is from the Amsoil web-site. Hope this helps. Jeff
Please click on any of the product links below for more information or to make a purchase.
1993 DODGE TRUCKS W350 4WD PICKUP 5. 9L 6-cyl Engine Code 8 TurboDiesel
FILTERS
Oil Filter... ... ... EAO80 Absolute Efficiency Oil Filter
Oil Filter... ... ... ELF7349 ELF7349 Donaldson Endurance Oil Filter
Oil Filter... ... ... 51607 WIX 51607 Oil Filter (O)
Air Filter... ... ... 46338 WIX 46338 Air Filter (O)
Fuel Filter... ... . 33379 WIX 33379 Fuel Filter
Trans Filter..... 58707 WIX 58707 Trans Filter (S)
TRICO WIPER BLADES
Blade Class Driver Passenger Rear
NEOFORM T16180 T16180
EXACTFIT T182 T182
WINTER T37180 T37180
OKTANE 18 inch 18 inch
LUBRICANTS & FLUIDS
Engine Oil
Grade 1... ... CI-4
SAE 15W-40 Synthetic Heavy Duty Diesel and Marine Motor Oil
Synthetic Blend 15W-40 Diesel Oil
Synthetic 5W-40 Premium Diesel Oil
Series 3000 Synthetic 5W-30 Heavy Duty Diesel Oil
-23 To -12°F... ... 10W-30[1]
Above 10°F... ... 15W-40
Below 0°F... ... 5W-30, 10W-30
Manual Transmission,G360..... SJ
5W-30
SAE 0W-30 Synthetic Signature Series Oil
SAE 5W-30 Synthetic Motor Oil
SAE 5W-30 XL Synthetic Motor Oil
Automatic Transmission..... AP4
Synthetic Automatic Transmission Fluid
Differential, Front ..... GL-5
All Temps... ... 80W-140, 85W-140, 80W-90
Severe Gear 75W-140
SAE 80W-140 Synthetic Gear Lube
Controlled Slip Differential, Rear ..... GL-5*[2][3]
All Temps... ... 80W-90
SAE 80W-90 Synthetic Gear Lube
Severe Gear 75W-90
Transfer Case,NP241LD..... AF2
Torque-Drive™ Synthetic Automatic Transmission Fluid (ATD)
Transfer Case,NP241HD..... AF2
Transfer Case,NP208..... AF2
Transfer Case,NP241HD..... AF3
Transfer Case,NP241LD..... AF3
Transfer Case,NP208..... AF3
Transfer Case,NP241LD..... AP3
Transfer Case,NP241HD..... AP3
Transfer Case,NP208..... AP3
Transfer Case,NP205..... GL-5
Above 32°C... ... 140
No AMSOIL Product Recommendation
Below -23°C... ... 80W
Severe Gear 75W-90
SAE 75W-90 Synthetic Gear Lube
Above -23°C... ... 90
Severe Gear 75W-90
Transfer Case,NP205..... SJ
Above 0°C... ... 50
Synthetic Powershift Transmission Fluid SAE 50
Below 0°C... ... 30
SAE 10W-30 Synthetic Motor Oil
SAE 10W-30 XL Synthetic Motor Oil
Fluids
Power Steering Fluid..... PS
Brake Fluid..... HB
Clutch Fluid..... HB
1. 10W-30 recommended below -18 °C (0 °F) W/ block
heater only.
2. CS IDENTIFICATION: Lift both rear wheels, turn a wheel and
other will rotate in same direction.
3. With controlled slip, add 6. 5%
Mopar Trac-loc additive.
CHASSIS LUBRICATION
7-11 Fittings, 0 Plugs... ... ... . BJ
CAPACITIES
Engine, without filter... ... ... . 11. 0 quarts[1]
Cooling System, W/ AT Initial Fill... ... ... . 17. 0 quarts
AMSOIL Antifreeze and Engine Coolant
Cooling System, W/ MT Initial Fill... ... ... . 16. 0 quarts
Automatic Transmission, Initial Fill... ... ... . 4. 0 quarts[2]
Automatic Transmission, Total Fill
4 speed ... ... ... . 10. 0 quarts
3 speed EX A727... ... ... . 8. 6 quarts
3 speed ex lockup A727... ... ... . 8. 6 quarts
3 speed lockup A727... ... ... . 8. 4 quarts
Manual Transmission, ... ... ... . 7. 0 pints
Manual Transmission, NV4500... ... ... . 8. 0 pints
Manual Transmission, NP435... ... ... . 7. 0 pints
Differential, Dana 60 Rear... ... ... . 5. 9 pints
Differential, Dana 70 Rear... ... ... . 7. 0 pints
Differential, Spicer 44 Front... ... ... . 5. 7 pints
Differential, Chrysler Rear... ... ... . 4. 4 pints
Differential, Spicer 60 Front... ... ... . 6. 5 pints
Transfer Case,NP241HD... ... ... . 5. 9 pints
Transfer Case,NP241LD... ... ... . 4. 6 pints
Transfer Case,NP205... ... ... . 9. 1 pints
Transfer Case,NP208... ... ... . 5. 9 pints
1. Add extra oil when replacing filter.
refill check oil level.
2. With ENG at operating temperature, shift through all
gears. Check fluid level in NEUTRAL and add fluid
as needed.
TORQUES
Oil Drain Plug..... 44 ft-lbs
Transfer case NP205/241
Fill Plug..... 40 ft-lbs
Drain Plug..... 40 ft-lbs
Transfer case NP208
Fill Plug..... 18 ft-lbs
Drain Plug..... 18 ft-lbs
Manual Transmission
Fill Plug..... 35 ft-lbs
Drain Plug..... 35 ft-lbs
SERVICE INTERVAL
AMSOIL Product Recommendation and Drain Interval Guide (g1490)
OTHER TOP QUALITY PRODUCTS
Mothers® Car Care Appearance Products
By-Pass Oil Filters
