Amsoil
what can I do for more hp?
engine adapter/ bellhousing
If you want to phone order you can use my ZO# 417944 and get the oil for dealer price. :D
Amsoil's # is 1-800-777-7094
You need a credit card and you need to give them an address to ship to.
Do you need any product codes??
FL70CAT= Thanks for the offer. Was contacted by Amsoil Dealer and got all set up. I have my own bisness in Nv and all the info he needed. Just had to find someone to work with.
Agen thank you for the help.
Harlan:rolleyes:
:) Hey Harlan, have you decided to use Amsoil in your rigs? If so, have you seen a benefit to so so? Hows the egt so far with the pod injectors? I saw the post you had to turn down the fuel, did you? I'm kinda in limbo presently with some family issues, but hopely will soon get back on the truck. Do you like the Pacbrake? Thanks Harlan, Tim:) :) :) :) :)
Tim1=I am going to Amsoil with my ext Oil change. Turner the power screw back out 1 1/2 turns and am going to run it at this setting till I start to tow my big trailer this sumer and see how it Works out. By backing the power setting my boost droped to 36lb but I am at 5000 to 6000ft and this will change when I go to a lower altitued. Will see what the EGT is doing when it gets hot. Just orderd a new South bend clutch, the rear main started to leek so whall in there figured to up date the clutch at the same time. Piers thinks I am about toped out for power. But will work on that at a later date. I can not realy tell till I tow the trailer in a month or two. Will have the GEAR VENDER in by then and will know a lot more.
Harlan:rolleyes:
