Engine/Transmission (1998.5 - 2002) AN fittings
Engine/Transmission (1994 - 1998) twins ...triplets?
Ok what size is needed for VP44 inlet, fuel filter canister inlet/outlet and LP inlet/outlet. Any sources out there as well and since I am changing the under hood colors to blue are there any sources to get colored fuel lines.
Thanks
Scott
There is an active thread right now under accessories for engines and trannies, large lines and fittings I was there last night and found all kinds of stuff. I ordered a kit this am from vancouver washington to turn my pump into a pusher.
Summitt has the AN fittings you need. They have a 12mm to -6 for all the connections on the pump and canister. And you can use the blue push-loc hose, same as the hose that comes with the RASP kit. A lot easier to plumb than braided hose.
Tom
