AN1 know a shop in the D/FW area that can bend 4" tubing??
T-case np 205 bad noises
Are early 89-91 cylinder heads really that bad?
Don't know if there are many members here from the D/FW Texas area... . I'm trying to find an exhaust/muffler store that can bend 4" tubing and not having any luck... anyone know of one in this area?
Thanks.
bgilbert said:
If you are looking for an exhaust system for your crew cab, try : http://shop.ivalueinternet.com/bigexhaust/index.cfm/action/productdetail/product_id/2426.htm. That is www.bigexhaust.com. They supply enough pipe for a crew long bed. EarlKann used this kit for his crew. ~$300.
I went with the Stan's Headers kit... unfortunately it does not fit quite right because the frame on my Crew is different than the '89-'93 Diesels. At least I know my '92 donor frame was different. The center section of the truck, the frame on my '92 was a 8" C-section, while on the Crew it's a 6" C. Thats where the problem is (the exhaust kit is NOT the problem... . the quality is great and it would probably fit like a glove on the intended year models). That 2" difference places the crossmember where the carrier bearing bolts up right up against the exhaust pipe.
Your donor was a 350 correct? My 91 W250 has a 6" frame just like your crew. I wouldn't think they'd make a different kit for each frame? You can't just jockey it around a bit to make it clear?
Travis. .
My donor was a '92 W250 Club cab... . maybe they changed the frames in '92? I read somewhere else on here where someone stated they indeed went with a 8" frame (middle section) on some 1st Gens.
I've tried jockeying it around some... . just wont quite clear.
