Originally posted by Gary - KJ6Q
OK, after some thought, a question/theory...
Sticks, exactly WHAT/where are you sampling for the graphs you posted above? One seems to be labeled operating with the cruise control engaged, the other is labeled "idle"
I can sorta understand why the line display would be jagged in CC, since the ECM would be constantly making minor running adjustments to engine fueling/RPM to maintain a steady speed - not a "flat line" as with an old-fashioned throttle cable that merely holds the throttle to a single selected position, regardless of engine RPM...
So, what exactly WAS that graph monitoring?
The graph is monitoring the APPS sensor output not what the ECM/PCM decides the engine is running at. The OBDII software samples the sensor about 3 times per second. If I add another sensor (RPM, Speedo, IAT, MAP... ) then it samples each one about once per second, and it gets slower for each additional one I add. That is why I have only been monitoring the TP% because the spikes rarely last for more than one second.
My cruise control is all electric. So the APPS sensor has no effect on the engine operation until it is depressed past the point that the ECM/PCM (whoever is controlling the engine speed with the cruise engaged) is operating, and the cruise control has no effect on the APPS readings. I apologize, when I refer to "Idle" I mean foot is off the throttle, and the APPS assembly has returned to zero. So in the above scans, the cruise control is engaged on the highway at 75mph, my foot is off the throttle, and the APPS output is jumping all over the place in the top one, and the bottom one, I am still running down the highway at 75 with the cruise, and the APPS output returns to normal.
I have scans with the truck sitting still, and FOT (foot off throttle) at idle, and the scans look the same (and the percentage numbers are the same), only the RPM's are jumping from 800 to 1200 and anywhere in between. Sometimes it will hold the higher revs for a few seconds then drop off, others it just jumps up and down like I am goosing the throttle.
Variations of . 4% does not make a noticeable difference - running normal and the TP% in the scan shows 9. 0 - 9. 4 and looks like an EKG. Variations of 4% (9. 0 - 13. 0) makes for an irritating drive, annoying at stoplights, and a bit harrowing in stop and go traffic.
