OK, but ONLY because you asked... ... ... ... .....
IMHO you are making a mountain out of a mole hill. Kick back and have some lemonaid cuz that is what life just handed you..... NOT lemons.
You need that air pressure line (from the cylinder head to the pump's AFC top cover)just about as much as you need a leaking rear main seal. I does nothing for the cause unless;
You want to keep the engine 100% OEM
You have VERY strict emissions testing/laws etc.
You personally are apaulled by any smoke whatsoever.
You are afraid of what it'll do to the engine if you simply throw it in the trash can.
The worst that will happen is that you'll notice a tad more smoke when you hammer the throttle. Because you have a manual transmission, you'll likely see a puff when you get back into the throttle when up-shifting. But hey who doesn't see some visable exhaust, right.
Ok, most folks think I'm blowing smoke here... ... ... ... . literally. But try it out for yourself. but Please plug the 1/8" pipe tap hole in the cylinder head.
That's all I have to say... ... .
