Engine/Transmission (1998.5 - 2002) Angle for Oil changes
Engine/Transmission (1994 - 1998) PTO install on a nv4500
What is the best angle to park truck for changing oil?
I've always done it with level truck, but somebody gave away their ramps (strong one's) and I'm not sure if that would hinder any oil from draining... yeah I know, kooky question but hey, that's what forums are for, right?
Wish you could get ramps with longer tire patches so I could drive up on two in front, slide two more behind rear tires, than back up to raise whole truck up to same level. It would be a cheap "short" lift.
Thanks, folks.
-Jack
Maybe jack your truck to the angle the ramps would place it in, then drain the oil. When it stops dripping, remove the jack and stands and set it level. If more oil comes out, I think level would be better. A slight angle shouldn't matter much.
