2nd Gen Non-Engine/Transmission Another ABS Problem
Engine/Transmission (1998.5 - 2002) Warranty?
Engine/Transmission (1998.5 - 2002) Quietest 4" diameter muffler
Ok, like I wrote on a previous thread, I have a 2001 Dodge Ram 3500 4x4 Dually, Diesel, Auto. So far I have replaced the ABS module atop the ABS pump on the driver's side inner fender and have also replaced the rear end sensor. On Tuesday I'm going to bring the truck to a local shop and see what electronic testers can find on this truck. Does anybody have any suggestions as to what is making the ABS and Brake lights come on. I turn the key to run and the ABS and Brake lights stay on then when you turn the key further and start the engine the lights go off and then come back on a second later. Then a few seconds after that, they go off, then they come back on and stay on until the key is turned to the off position. If anybody has any suggestions as to what else could be wrong it would be appreciated, especially if I don't have to bring it to a shop, Thanks.
