I have looked through the previous post for ac problems but am not seeing the problem that I am having. I do not have a leak or if so a very slow leak. The system holds good pressure, but just is not blowing cold air (65 degrees F. ). Outside air temp was at 88, low pressure was at 55. I have found that the lower the low pressure side is the colder the air at the vents. The problem is when I set the pressure at around 40 psi at idle, when you drive the truck, the compressor cycles because I believe the low pressure is drops below 25 psi. I tested the low pressure switch and when pressure drops below about 23 or so the compressor kicks out. It seems I have to have my low pressure higher at colder temps to keep the compressor from disengaging but than at higher temps the low pressure is high and my vent temps are high. I removed the blower fan and looked up in and didn't see any debri. My drain is clear and working. Are these systems that inefficient? My father in laws Dakota has 39 degree temps at the vents :--)
