In most of the anti-theft threads there are several cautions about changing wiring under the dash is easily seen etc, etc etc.
OK, how about doing under the hood?, say the Crank Position Sensor or the Cam Position Sensor? The idea goes like this:
Cut any ONE of the wires that come off the CKS or CMS and put a 2KoolTech.com pulse wireless receiver in it with the relay to complete the wire circuit off the CKS or CMS that you spliced the pulse wireless receiver into where you cut. You tuck the pulse wireless receiver where ever you want that is well out of the way (probably spray paint it black as well). You run the pulse receiver wire up into the OEM wire loom that goes to the CKS or CMS so it is not easily detected.
I think I am right in that if the CKS or the CMS is not providing a engine rotating signal the ECM will not allow the engine to start.
You wind up with another key fob, so it is not going to be defeated if the theives got the VIN and had a key made and opened the door and used the correct key they had made.
Your 2KoolTech key fob can control up to 5 different pulse wireless receivers if you want to add other On / OFF type theft deterrents (lift the Fuel Control Relay B+(12 volt power) that powers the VP44 control circuits). Could also use the RM01 from fourwinds-ii.com, or sailorssolutions.com, or directron.com, same idea.
Just another idea, trying to build a better mouse trap.
Of course it does not do anything for towing the whole truck.
I think the thieves could look under the dash (not there), pop the ignition switch and change it (not there), do anything inside the truck (not there), pop the hood and start looking, hummm, now where is whatever we are not sure we are looking for going to be - GOOD QUESTION
Bob Weis
Bob Weis
