Another Auto Trans ??
Why Johnnie Can't Think
Outnumbered
Is is normal for a transmission that has set for 3 years to be about 3 quarts HIGH on the dip stick?
Is it moisture?
Has the converter drained back?
Oil cooler ruptured?
I can see how the convertor could leak back over 3 years causing high fluid. Did it work when the car was stored? If yes, start it up, move it and then check the fluid level again.
