I read this on another forum and it sounds like a good idea to me. There weren't many responces so I'm posting it here to see if this is possible to do.
I'd like to add an aux fuel tank between my rear fender and frame rail.
My question is would it vacuum feed if I tied the vent hoses from the main tank to the aux tank?
There has to be some kind of ventilation for the main tank. My thoughts are move the vent hose from the main tank to the aux tank and then run a transfer hose from the aux<textarea name="message" id="vB_Editor_QE_1_textarea" rows="10" cols="60" style="width:500px; height:200px" tabindex="1" dir="ltr">I read this on another forum and it sounds like a good idea to me. There weren't many responces so I'm posting it here to see if this is possible to do.
There has to be some kind of ventilation for the main tank. My thoughts are move the vent hose from the main tank to the aux tank and then run a transfer hose from the aux tank to the vent hole in the main tank.
The two things that would kill this idea are 1. If I need a fuel pump to move fuel between the tanks. 2 The cost of the tank vs how many gallons the tank will hold. If I can't get 15 gallons it's not worth it. I'll measure the opening and figure out what will fit in.
One guy said it would cause the main tank to leak from the pickup. Do you guys think the suction needed would collapse the main plastic tank?
Thanks
Thanks
