another EZ question .......
need help.....
Any problems with using EDGE EZ for 600
Sometime within the last 2 or 3 weeks I read a post about making the EZ adjustable. I can't remember if it was on TDR or DTR, but a quick search yielded nothing (maybe I was dreaming).
Anyway, I kinda breezed throught it without another thought. Then, tonight while in the shop that thread popped into my mind after several weeks :confused: .
Anyway, the cables on the EZ are plenty long enough to hide the box under the dash somewhere. From there, six leads could be soldered to the pins heading to 3 dip switches. The dip switches could almost be mounted anywhere! They are small and I've seen safety dips on machine controllers the require you to pull, then move so they can't be easily bumped out of position! Tonight on the way home I even looked at the small, flat, vertical area above the instument panel ... ... ..... no labels, just some dips ... ... ... ... ... . and if we ever get a juice, think of that!
Yes, I'm waiting on the juice or whatever it's called? Squished grapefruit?
I know some guys are already stacking EZ with some sort of timing/duration box ... ... ... ... . and with mixed results. Some have no trouble, some have bunches. I'll wait just to be sure what is coming down the pike.
Anyway, I'm starting to envision a series of unmarked dips on my dash that are barely visible but yet so powerful!
