Well my fuel heater here in Florida apparently came on this morning and something happened and now I have fuel coming out of the black plastic cover that has the heater harness going in to it. I did a few searches and there are a few things you can do to fix this. Some people have punched out the heater tapped the hole and put a plug in it. Some have used a freeze plug and some have used JBweld. If you have used the tap and plug method what size have you used? Also would jbweld hold? Not sure with all the vibrations. I have unplugged the heater since I will never use it. I want to stay with the stock canister configuration. Any info you can provide me would be greatly appreciated!
