another happy Smarty ♡ i'm in love
Exhaust brake vacuum pump failure
07 5.9 upgrades?? what's working and what's not?
i downloaded Smarty level 3 a few days ago, i've only ran a few errands thus-far, and i am a happy boy. Since my Westech is on the way from Geno's, i haven't really pushed on the pedal hard yet, but in just normal driving, it is way fun. Tomorrow, i drive from Taos to Denver and back, so i will be able to check fuel. The only confusing thing so far is the difference between each #, one is accomplished with fuel, the other timing, why??? what should i use on my stock truck?
The reason for the numbers are. If you are not running any other fueling timeing box run the sotware with timing, It helps with egts and fuel econemy. If you have some other box on ur truck that adds timing run the one with out increased timing. The software with out timeing is just the stock timeing curve as i believe and is not increased .
