I have heard the same thing as well... but most agree that over 50 is pushing it on stock head bolts with studs I would think around 70ish maybe a little more. Thats just me... .KKunz,
About 3 psi less than what it blows at!
Seriously, I have heard of a sled pulling truck that the head has never been off of that runs 80 psi. The head bolts are re-torqued on a regular basis.
Godspeed,
Trent
If your drive pressure ratio is 1:1 then they are equal factors, if not 1:1, then drive pressure is more important.Let’s just say the stock gasket with head bolt is good for 50 lbs of boost, if I’m running 1:1 drive pressure then the head gasket should hold? What is a bigger factor in head gasket integrity boost or drive pressure, or are they equally important?
Thanks for the replies it all make sense. As far as the head stud retorque go what intervals do you do them at? Do you eventually not have retorque them or is it some thing that must be done for the life of the engine?
