Shelby Griggs
Yes, I know this has been pretty well discussed in the past, but for other new(er) owners I thought I would pass along my first experience. First off, I modeled my efforts after dmurdock's instructions on his web page.
http://home.austin.rr.com/murdocks/oil.htm
It was still a bear to budge the filter, but I am quite certain that the back ordered oil filter pliers that I did not get in time, would have been a failure. That order will be canceled tomorrow. That strap wrench set up is sweet, and did the trick, but not before crushing the filter can. Then after it started moving, I still had to apply a bunch of torque for the first 1/2 turn or so.
Prior to removing the filter I removed the airbox to turbo hose, helps a bunch. I covered the turbo inlet with plastic wrap held in place with a rubber band. Placed a piece of cardboard over the RH battery so I could lean over without being on the battery. Also if you are short and have a 4 X 4, a step stool of some sort is in order. I have a two stepper from Wal Mart about $8. 00.
Lets see, fixes from dumb mistakes department. I leaned to hard on the airbox, causing the outboard rubber mounting post to unattach. Fought that for a while, figured out that it is not easy to remove the post, as the backside is between the fender and the fender liner. A shot of silicon spay lube a little pressure and it shot right back on there.
Found the OEM plug to be barely torqued at all, I am surprised it wasn't dripping.
Installed a Fleetguard filter (pre-filled of course) and added the finger touch drain valve and then topped it up with 10 more quarts of Valvoline PB 15-40.
Decided to remove and clean the breather tube and bottle. What a mess that thing is creating. See my tirade about this in my "What is it that smells in engine oil?" post in the Products forum.
No leaks, just lots of stink now in the cab, whereas I had none before the change.
Shelby
2001. 5 2500 QC LB 4WD, ETH (Built 09-10-00), DEE, 3. 54 gears, Laramie SLT, Camper Special, Trailer Tow, Travel Convenience Group, Power Driver Seat, Alarm System, Remote Keyless Entry, Fog Lamps, Cab Clearance Lamps, HD Transfer Case, Bright White with a Gray Interior. Built 09-15-00, took delivery on 10-06-00, 3873 miles as of 01-04-01. Custom aluminum work body / flat bed. Coming soon: E-Brake and gauges.
Shelby
