Engine/Transmission (1998.5 - 2002) another injector question???
My 275's injectors are on the low side from 3750 to 4050 psi . A upgraded vp-44 has been ordered so. Should I go for 300 injectors or replace them with the same thing.
Thanks for the comments and suggestions.
Your injectors can be shimmed to bring the pop pressures to where you need them. If you are happy with the power you have, that's all you need. If you want more power, then the aftermarket has plenty of options.
