Uhhhhh... ... . wait a minute. I'm an idiot. For some reason I thought you were talking about boost. My bad!
For the injection pump to function correctly it needs to have a MINIMUM of 5psi. If it does not, you can have a loss of power or even worse, injection pump failure. It sounds like you have a bad lift pump. My advise is to read up in these forums about either aftermarket pumps or relocating a new OEM pump. And get it changed ASAP or the injection pump will go bad also.
Good Luck
-Kyle
