Changed my transmission oil yeaterday. Since I was installing Geno's transmission oil filter where the PTO cover goes on the passenger side, I drained the old oil out there. With 16,000 miles(mostly towing a light TT), the oil looked like new. Probably could have waited until 30k miles. I installed the filter & refilled the transmission with Pennzoil Synchromesh. To my surprise, it only took 4 qts to fill it to the bottom of the fill hole on the drivers side. I'm sure I read in the TDR mag that it would take 5. 2 qts with 8 oz going to fill the new filter. I took it for a drive and rechecked the oil level while on level ground. It was full up to the bottom of the fill hole.
Is 4 qts all that it takes?
I noticed on the test drive that the transmission seemed to shift easier and smoother.
I could not find the reported magnet on the bottom but I was very impressed at the size of the two gears I could see.
