Engine/Transmission (1998.5 - 2002) Another NV5600 ?
Engine/Transmission (1994 - 1998) Serious Problems?
2nd Gen Non-Engine/Transmission Who sells PSC steering box?
I've got a early 5600 that had the small input shaft I'm changing it to the 1. 375 I know I have to get a differnt flywheel and put a spacer in the starter but what about the clutch fork does anyone know if it is different also what is the difference in the flywheel other than the bigger clutch I'm guessing that it sets closer to the engine thats why you have to add the starter spacer does anyone know where I can get a flywheel for the 01-02 six speed and one more question If you by a southben clutch for the 1. 375 input do you not get the fly wheel with it ? :confused:
The diameter of the starter ring is a little bigger on the new fly wheel. They added a little extra "beef" around the bolt circle for the pressure plate. Give Peter a call. He can supply the new flywheel, probably on an exchange basis.
