Fester,
First off, one must uderstand the term "viscosity. " When a fluid is subjected to external forces, it resists flow due to internal molecular friction. Viscosity is a measure of that internal friction.
So, Viscosity becomes the
most important characteristic of a lubricant.
Viscosity can be viewed in two different ways. The first is a fluid's tendancy to flow as is visually indicated. One can think of this as the time it takes to
watch a fluid pour out of a container. The term used to describe this is
Kinematic Viscosity and it is expressed in units indicating flow volume over a period of time.
The most commonly used unit of
Kinematic Viscosity is the
Centistoke (cSt) . Another is a
Saybolt Universal Second (SUS or SSU).
When comparing the Viscosity of two different fluid's, keep in mind that a Centistoke and a Sabolt Universal Second are two different Units. Therefore, they cannot be accurately compared.
The temperature of the fluid being tested will also affect the outcome. The
Kinematic Viscosity of a fluid is determined at 100 C (210 F) and or 40 C (100 F) depending on the grading system being used. For general comparison purposes, the temperature at which the Viscosity was determined has to be the same.
The second way Viscosity can be indicated is through measured resistance. You can think of this as the energy required to move an object through the fluid. It takes little energy to stir water with a spoon. However, significantly more energy is required to stir honey with that same spoon. The term used to describe this is
Apparant Viscostiy and it is expressed in units known as
Centipoise (cP).
The SAE has established 12 Viscosity grades that are suitable for engine lubricating oils. This is known as
SAE J-300 Engine oil Classification, Dec 1999 The high temperature Viscosity for all engine oils is
always determined at
100 C. Muli-grade oils must meet the requirements for both high and low temperatures.
Are graphs available that show the typical viscosity of multi-weight oils across the temperature range?
Yes ther are graphs that will show this. I will try to explain the differences without doing a graph.
An SAE 10W will be suitable for low temperature application, but will thin readily as the temperature increases. The "single" grade oil such as a SAE 30 is suitable for high temperature applicaitons, but will thicken readily as the temperature decreases.
The multi-grade oil such as a 10W-30 maintains its Viscosity throughout, which makes it suitable for use over a significantly broader temeprature range.
There are certain "Base Stocks" that
may have the ability to function over broader temperature ranges, but most Mult-grade oils start with a "Base Stock" possessing the desired
Low temperature Properties, and add
Viscosity Index Improvers to reduce thinning as the temperature rises. We're talking oil temperatures here.
There are a number of other things that effect the Viscosity over a given temperature range as well. One of them is
Viscosity Index. (VI) Viscosity Index is an empirical number indicating the
Degree of change in Viscosity of an oil within a given temperature range. A low VI number indicates a relatively large change. Numbers of 60 or below are considered low. A high VI number will indicate the ability to provide protection over a wider temperature range.
Hope this helps,
Wayne
amsoilman
