Does anyone have an idea what would be causing early lock up? Tried a lot of different things with no luck. The TC is locking up as early as 23mph with OD off. It should not lockup until 35 mph under light throttle. Checked and adjusted TPS voltage and TV cable. Pulled TPS wiring out of the loom about 18 inches. Checked and cleaned all connectors on transmission and VSS. Thought it might be lockup solenoid but the problem was present prior to recent transmission upgrades. I have not been able to find much on the TDR regarding early lockup. Most symptoms are associated with in and out of lock up at freeway speeds. I have not experienced that problem. Any other ideas would be appreciated.
Thanks
Steve
Thanks
Steve
