Just got done helping Boondock swap out his rear end in his '98 12v due to a bent housing. The replacement rear end came out of a '96. The speed sensor is not the same between the '98 and the '96. Then connector is different. Does anyone happen to know if we can just cut n splice the wires from the '98 to the sensor off the '96 axle? They both are only 2 wires, but the '96 is a red and black wire, and the '98 is a red and a white/purple wire. We can't just pull the sensor and put the other one in because of some tabs on top of the housing of the '96 axle, won't allow the sensor from the '98 to fit in there.
Right now the truck is up and running, but without ABS. The sensor is unplugged. The ABS and BRAKE light are both on.
Thanks... .
Thanks... .
