antifreeze leaking from inside belhousing.
What's this fitting?
05 5.9 mega cab is leaking coolant from inside belhousing any ideas from where? Are there any frost plugs back there? head gasket? broken block? this did this back in the summer so not a freezing issue.
So you pulled the inspection cover and can see it inside the bellhousing or its dripping off the bottom of the bellhousing? When the coolant hose behind the turbo was leaking on my truck is was dripping from the bottom of the bellhousing and looked like it was coming from inside at first glance.
I will re-inspect
I had a coolant leak (drip) that looked like it was coming from the bellhousing, but was actually coming from a heater hose and running down the block, and only when I had it plugged in at night. Initially it was that coolant hose behind the turbo that AEdelheit mentioned, then later it was from one of the Ts that I put in when I added a coolant filter.
