Just trying to get a feel if anyone has had this happen to them: Temps have been colder than normal here in Western Illinois for the past few weeks. Antifreeze in my truck is mixed at the correct level. Truck sat for a few days and once I went to drive it I got the smell of antifreeze in the cab when running the floor heat. Now this happens only when the floor heat is turned on. If I run the panel vents or defrost you don't get the smell. I checked to see if there was any external leak in the engine compartment but everything appears dry. Antifreeze reservoir doesn't appear to be loosing any fluid. Has anyone had this similar issue? At first I thought it must be the heater core but the panel vents get hot air from the same place. I'd rather rather not spend 8 hours pulling the HVAC distribution unit! Any ideas anyone? Thanks for the info.
