I have a set of AC gauges and have checked pressures. The low side cycles between 18 and 52lbs. The high side cycles between 130 and 155lbs. This at 90 degrees ambient. Center outlet temp in cab only gets to about 80 degrees. Can anyone give me some direction. I am suspecting the low pressure sensor being bad and have some misgiving about being overcharged also. I did attempt to add just a tiny amount of r-134a to see if it would bring my high side up. Should I jump the low pressure sensor to keep the compressor clutch engaged to get a steady reading on the low side? Or, do I have a bigger problem that I don't see.
