howdy fellers. 98 12v 4x4 155k. i bought the replacement fuel lines kit from larry b's and am ready to replace the old ones which i believe to be worn out and cracked. even if its between 70 and 90 degrees outside, when i start the truck cold i have to keep a little pressure on the accelerator to keep the truck from dying and it blows a good bit of white smoke in the first few seconds. after running for a about half a minute it will work its way up from 600 rpm to 800 and then to the set idle of 850 rpm. from the research ive done it sounds like my fuel lines are letting air into the system. anyway, ive never changed the fuel lines on this truck or any truck for that matter and was wondering if anyone had some helpful advice to make things go as smoothly as possible. thanks!
