I have the Glacier Diesel Fuel pump, but before I got it, I did some soul searching because I was concerned about giving up the fuel air separation function of the FASS. I was still fretting about it this morning, and wondering how I could add that function back in, and dreaming of ways to combine the nice quiet fuel-cooled Walbro pump that I like so much with the FASS filters. Then it hit me. What's the point of separating the air out of the fuel anyway?
Consider:
1) The whole point is to mix the fuel with air in the cylinder, so there's nothing intrinsically bad about air being in the fuel.
2) The only downside I can see is if the air is displacing the fuel being shot through the injectors.
3) The injected fuel is under around 10,000 psi or more of pressure, which is about 1,000 times its pressure when it was mixed with air in the tank.
4) Since the fuel is non-compressible, and the air is, the volume of the air will be about 1,000 times smaller relative to the fuel when it is put under pressure in the injection rail. So if the fuel started out as 10% air by volume in the tank, it will be . 01% air by volume in the rail.
5) A 0. 01% reduction in the amount of fuel shot through the injectors is not going to be measurable.
6) It seems like the little tiny high pressure air balls would assist in fuel atomization as they expand in the lower pressure of the cylinder chamber.
Am I missing something, or is there really no point to fuel/air separation?
The only possible benefit I can see is that if you are running your CP3 to the limit and draining the rail, a fuel/air separator might help the CP3 push a few % additional fuel into the rail, but if I was that close to the edge, I'd rather upgrade the CP3 than than mess with adding the fuel/air separation.
Consider:
