Yep - thats the same 2. 7. The sites that usually bash Chrysler (consumer reports.com, edmunds, etc) were not kind to the engine. Apparently it is prone to some kind of sludge build up causing an oil circulation failure. There is even one group putting together a class action lawsuit.
This post, from the squeakywheel.com kind of sums up the problem:
"My 1999 Dodge Intrepid needed to have the timing chain tensioner replaced at 65,000 miles which cost $1,300. At 69,000 miles the block cracked and I had to replace the engine at a cost of $5,500. Both problems were due to engine sludge throughout the oil channels in the engine despite regular oil changes every 3,000 to 5,000 miles. There has been no company notices, no warranty, no recall on this faulty design which causes the oil to overheat and clog the lubrication channels.
A possible solution for those who haven't blown an engine yet is to use synthetic oil, which won't burn like the petroleum oils. "
Philip - what kind of MPG's is your wife getting on hers?
Wayne - haven't tried ALLPAR yet but will go there next - thanks,
-Vic
