I have a 2001 Chevrolet Impala with the 3. 8, and have had the intake recall done. Basically they have a design flaw in the intake where they run EGR gas through plastic, it melts/deteriorates, and then dumps coolant either outside or inside your engine. So to fix it they put some new nuts on the intake and dump some stop leak (yes the ground up walnut shells) into the radiator, give you a smack on the a$$ and see you later. I can see the nuts - but the stop leak really rubbed me the wrong way. I get home and start checking things out, check to see if the radiator is full (gut feeling) and see the floaties in there and about lost it.
So I call the service guys chewing a$$ about what kind of bleepity bleep uses bars leaks, and they told me that's part of the recall. So I apologize, and ask them if GM has a new manifold design available, because I'm thinking of premptively replacing it. He said yes, but GM is not allowing anyone to order the new manifold until they've exhausted their inventory of the old crappy ones. So again I control my anger, politely thank the guy who obviously is having this conversation four times a day and can't do anything about it and crack a beer.
Then, I hear through the rumor mill that the 100,000 mile dexcool they put in there is prone to gelling, which leads to overheating, etc.
I guess what I'm looking for is the straight story on the intake manifolds, and on dexcool. Are the new manifolds available, and are they any good? Is dexcool junk, can I use the regular green antifreeze and just change it more? I plan on driving the car until the doors fall off - and the engine's a pretty important part of that plan.
sure wish they had a cummins retrofit for the impala's...
Thanks -
Dave
Thanks -
Dave
