Need help with a bit of a problem, the other day I noticed my voltage gauge go from 14. 7 or so down to around 10-12 volts, could smell sulfur smell, popped hood and saw passenger side battery steaming, with acid leaking out of vents slightly. Battery was HOT to the touch. I unhooked it, continuted my trip home, and battery gauge went right up to where it should 14. 7 or so.
I took my battery and truck to the local AutoZone used the battery and alternator tester. Battery tested good, alternator tested great too. I told them since battery was under warranty to swap it with a new one, they did, put in truck seemed fine, drove home everything good. Went to work next morning, same thing happened as before, hot, acid leaking, etc. Unhooked battery good on drivers side. What is going on here? Thanks in advance.
__________________
__________________
