Does anyone have any tricks or easy ways to remove the pitman arm on a '98. 5 4X2? I just tried removing mine and it was hopeless. I have a pitman arm puller, tried that, used penetrate on splines even tried warming up the arm hoping to get it loose, didn't want to get things too hot and melt the steering box shaft seal. My next thought is a die grinder with a 2" cut off wheel and making a cut on the arm to relieve the tension on the spline. Think that will work ok?? TIA gary
