Any knowledge on Cometic "Phuzion" head gaskets?
Can I use Smarty...
1st Gen NV4500 Conversion: Automatic
mls or phuzion
I was at the HTS open house and I am quite sure it was the Phuzion gasket. There was talk about it being an early production piece being put through its paces on the HTS truck. Wouldnt that make more sense to you guys since its holding close to 90lbs of boost. I mean we can all dream of a $250 gasket that will hold that with just 12mm studs and no O/Fire rings..... but then we wake up..... :-laf
My brother just got off the phone with cometic and they said they weren't going to make a phuzion hdgskt??? They also said they wouldn't modify the 24 valve gasket for the 12 valve, but the 12 valve gskt would be ready in about 6 months:mad:. Don't they know them there 12 valvers are making more hp than those overvalved computerized motors:-laf. They said that they were testing the mls gskt at 80+psi and it is holding. I don't know if they were using studs or not.
