Review by TDR Writer, Andy Mikonis (continued)
Driving Impressions
We grabbed a top of the line Laramie Crew Cab 4x4 which stickered out at $44,935 including $795 in options, and $900 destination. No RamBox, though there were Ram Box equipped trucks on hand. Interestingly, as of this writing Automotive News is reporting RamBox won't have a price tag until October and won't be available at the initial launch, which has some dealers miffed. They speculate it would be popular if priced cheaply, though the fact they are bundling it with the cargo management system might make it pricey.
On to the first part of the drive, it was about 100 miles of smooth California highway, which didn't tell me a whole lot about the truck other than it was quiet. A few nice comfort and convenience things jumped out. The gauge cluster is really nice to look at, with white on black numbers with a sort of backlit effect. Front windows are one-touch up and down.
All new half-ton trucks ride smoothly on smooth roads, so I was happy to see the afternoon's activities would take place around a ranch in a rural area with a variety of less than smooth road surfaces. The true test of the new link coil suspension would be how it rode empty, and by extension, if it would maintain good ride quality when loaded. I probably don't have to remind this audience that leaf spring suspensions are tuned to ride smoothly when loaded, at the expense of a bouncy ride when empty. One of the Dodge guys quipped that there's a factual basis for the expression “rides like a truck. ” In addition to the points we discussed in Issue 60, Steve Williams, senior manger of Dodge Ram synthesis put it very succinctly when he said the key advantage of the link coil setup was that it separated the duties of suspending and locating the axle.
As we rolled in to the ranch at lunchtime, I eyed the lineup of competitive trucks from Ford (a 2008 as '09 aren't out yet), Chevrolet, Nissan, and Toyota available for drives. I said to the Dodge folks they should have had an '08 Ram, to which they replied they did. I'm not sure how I missed the “Detonator Yellow” 2008 Ram 1500 Quad Cab Sport Hemi 4x2 sitting out there. This will make for a good comparison.
In any case, I took the 2008 Ram out after lunch on a recommended drive loop. My first thought was this really isn't too bad. I was even thinking I could live with one at the bargain basement prices I've been hearing about as they close out the 2008s. The white-faced gauges looked a little glaring to me, but the plastic factor of the interior and the relative bounciness of the ride seemed fairly normal to me as a truck guy.
Upon returning, I was pleased to find an equivalent 2009 Ram, a Sport Quad Cab Hemi 4x2. It was at this time I blew what was to be my only chance to drive the one R/T package truck they had available. It has unique R/T badges, a 4. 10 rear axle ratio, a special torque converter and is said to do zero to 60 in under six seconds. But, I wanted to be fresh in my comparison to the 2008 on the same roads. The verdict? Big difference. It's not that the bumps disappear, you still feel it in the suspension, but the body doesn't move nearly as much. Additionally, the front end feels a lot more stable and planted since the rear isn't bouncing around.
While I was most interested in driving the new generation Hemi, my next experiment was to drive a stripper 3. 7-liter V6 Crew Cab. There was no sacrifice in ride quality. At this point, I stopped at the off-site towing demonstration. There were Rams hooked to a boat and a horse trailer, but I took a 20-mile drive in one towing a 5800-pound Airstream. A vehicle synthesis engineer who had been working on the Ram suspension and steering for the last three years rode along. We discussed my observations, and he added that with the improved ride quality of the link coil suspension, they were able to make the steering more responsive and dial in less understeer, which results in a better handling truck. He also said there are some tuning differences for different models, but that is so the different size trucks and tires have similar ride and handling qualities.
As far as towing, I could definitely feel the trailer, whereas I may not have in a Heavy Duty, but it felt stable, and ride quality was smooth. The ESP, Electronic Stability Program, includes trailer sway control, but I didn't feel it engage. Running at the 55 mph speed limit, the transmission was fishing in and out of overdrive quite a bit. Judging by brisk acceleration with the trailer, the Hemi wasn't lacking power, so I think that speed was in between the ideal gears. I couldn't help but think it would have been happier at 70 mph.
Next, I did the drive loop in a Crew Cab Hemi with 1000 pounds in the back. That cinched it for me. There was no appreciable difference in ride quality loaded or unloaded. On a side note, this truck had the heated and ventilated front seats. It was parked in the sun, but the ventilation feature cooled the seat very effectively. This option will automatically cool the seats when the optional remote start is used above 70 degrees. Similarly, it will automatically heat the seats below 40 degrees. Nice touch.
Since this is a diesel magazine, just a few notes on the gas engines. The 3. 7-liter V6 and 4. 7-liter V8 are carried over. The next generation Hemi with variable valve timing boasts some pretty impressive numbers on paper, with horsepower and torque up to 390/407 from 345/375. My initial seat-of-the-pants impression was there was not a significant difference in acceleration, though to be fair, I had less than 20 miles in the 2008. The biggest advantage seems to be that the four-cylinder mode can be used longer and more often. EPA estimates jumped one to two miles per gallon depending on configuration.
That basically concluded the day's activities. My driving partner from the morning and I were the last journalists there, and were left with the only Ram available -the same stripper Crew Cab I drove earlier - for the drive back to the hotel. Good thing we started the day in a Laramie instead of working our way up! We compared notes on the way back as he had done the opposite of what I had and drove all of the competitive trucks. I have driven them all in the recent past with the exception of the Toyota (not for lack of trying. ) He felt the Ram was by far the quietest, thought the Chevy had the worst steering, and that the Toyota Tundra with the 5. 7-liter V8 had the best engine and transmission.
The 2009 Ram 1500 banks heavily on appealing to personal use owners. It's a sound idea to differentiate more from the Heavy Duty lineup. Anyone towing and hauling a lot can pick up a 2500 or 3500. Unfortunately, that type of private half-ton buyer is becoming more rare in the current economic climate, and forecasts for long-term gas prices don't bode well for the future of pickups in general. But there are still a lot of pickups being sold, and the Ram 1500 will certainly win some people over from the competition. I wish them luck with the Ram 1500 - it's a great product. And one thing's for sure: it'll make a fine platform for a light duty diesel.
Andy Mikonis
TDR Writer
Note: We will repost this on the TDR Home Page with photographs as well.
