This is real application, no tricks. My pea sized brain is sore from trying to figure it out. Any takers?
I have a four sprocket machine that is missing three sprockets. The first 12 tooth sprocket needs to turn 8 times to make the last turn 5 times, the middle sprockets are both on the same shaft. How many teeth should the each of the missing sprockets have? None of the sprockets can be over 24 teeth.
