Any of you guys tried Duplicolor's do-it-yourself spray-in bedliner kit?
Rickson 19" on 1st Gen
Considering the stax......
$49. 95 at PepBoys seems like a mighty good deal.
http://coffeewithJesus. homestead.com/web1.html 89 1-ton, Amsoil System 3000 5-30,K&N air filter, cleaned-up exhaust, Dynomax straight-thru, rebuilt pump, 12cm wastegated turbo, thermostaticly controlled twin 14" electric fans, intercooler, modified 518 OD transmission, Gear vendors OD controler, R-134, louvered fenders, 93 aftermarket smoothe grille; 78 35'Avion, 93 Lance 900 slide in with generator and power jacks. Jesus saves!
Yes I have Used it, And its Ok, Just Follow the Instructions to the tee about the dry time between coats.
I used it on my Jeep Cherokee in the back cargo area. Once Dried, Its pretty tough. I was rushed for time and just poured the whole can on because I was just going to put carpet back in over, Did'nt real care what it looked like, just want the Moisture protection.
Doug.
1998. 5,2500,ISB,Auto,CC,4x4,4. 10's,Suregrip,White Sport,Isspro Boost & Pyro,275hp Injectors,VA,PS Boost Module,DTT Valve Body,BD Pressure Lock,16x8 Eagles,285/75/16 Bridgestone MT's,2. 5" Skyjacker Lift,Stockland Seibring Shell.
They've also got Herculiner there for $99. 95. It's got bits of rubber all through it. Makes for a really rough texture. I'd hate to fall and scrape something on it. reminds me of 80 grit sandpaper.
