Here is something I've often wondered about. Tell me if it seems right to you. I have well water and it enters the basement through 1. 25" O. D. black plastic pipe. It immediately goes to a 1" shut-off valve and then out of the valve it is reduced to 5/8 O. D. copper pipe which goes to my softener. It is again 5/8" coming out of the softener to the water heater and throughout the house.
For some reason I've always been under the impression that your hot and cold supply pipes through the house should be of a larger diameter than the feeder pipes leading to the various fixtures. Kind of like a heavy gage wire coming into your breaker panel, with smaller wires to the various branch circuits.
I was further pressed to ask that question since I bought a new softener yesterday and the installation manual says:
"In and out fittings included with the softener are 1" (nominal) copper sweat tubes. You should maintain the same, or larger, pipe size as the water supply pipe, up to the softener inlet and outlet. "
So does that confirm my theory? I figure as long as I'm sweating this thing in, now would be a good time to increase my hot and cold lines diameter. Or would that be unnecessary?
Roy
Roy
