I've had no luck with the Westach fuel gauge (0-30 psi) and senders (I'm using the FASS fuel pump system). I've gone thru two senders and two gauges over the past two years. The gauges (both of them) worked for a couple of months and started acting erratically, sometimes on start up the indicator needle sticks at 0 psi or 10 psi, If I tap the gauge housing the needle jumps back up to 16 psi (verified as correct with mechanical engine gauge). I've double checked my connections (mechanical and electrical) again and again, everything seems to be ok.
When I complained to Geno's where I bought the westach stuff, the first thing they asked me was if I had a modified fuel system. They seem to be hearing about failures when used with modified (fass etc. or additional lift pump mods) fuel systems. I know how much more the fass system flows (than stock) to be able to maintain my rock solid 16 psi at WOT, so maybe the flow is hard on the westach gauges.
Does any one have experience with the SPA fuel gauge (dual gauge) on modified fuel systems. I'd like some input before I spend almost twice the money (as westach) on the spa gauge (I do like the fact that it includes a programmable warning light for low fuel pressure).
thanks in advance
Jon Ebia
Albuquerque
thanks in advance
Jon Ebia
Albuquerque
