Details here: TDR Privileges
Am swapping out differerntials , new on has a differenrt plug on the ABS sensor on the pumpkin, hate to wreck anything, how do your remove the ABS sensor>?
If it is still same as 2nd generation it is not a problem to change. It slips into a hole in top of differential housing and has a small tab on the side with hole in it and a small hex head cap screw that holds it in place. There is an "O" ring for seal I believe. bg
