we just did my clutch today and wasn't too bad i thought. When you put it back in put the transmission in gear and put a vise grip on the output shaft so you can turn it and get it started a little easier. Don't clamp the vise grips real hard. then just walk it in slowly. It should go right together once it is started through the disk. Mine went in flush with the flywheel housing and then just put the bolts in. I wouldn't advise getting longer bolts or anything to try to pull it together as you can break the disks and other things that way. hope it helps. we did mine in a little over 3 hours on the lift.
