So, i have a truck with a no start issue. Just to be clear, it does crank, but does not start. Last post, we had a misunderstanding about the terminology. But anywany. the first truck won't start at all, except with either. The second truck will start but only after cranking on it for about 30-40 seconds. This gets worse once it is warm. Every now and then it starts right up though. I have ruled out about everything except the injector pump and injectors on both trucks. I have also tried the FCA. Didn't fix. So, is there any way to test the injector pump and injectors while they are in the truck? What should rail pressure be at idle and at WOT(both trucks are stock, one is 03, one is 04). When running, neither truck sound like they have injector issues, but i heard they could be leaking pressure off when cranking and causing no start. Fuel inlet pressure is good and releif valve is good on both trucks. Any ideas or ways to check pump and injectors? Thanks in advance for your help.
