Here are the links that make up my complete system. It started out, to just allow me to have an aux jack for my very expensive REC NAV option for my 07 C&C, you'd think that Dodge would have had an aux jack incorporated into it. The Lockpick I linked to, was the first accessory I installed, and I quickly found out the video input was an awesome option with the Lockpick. Then I had a couple of CEL's pop up on my dash that cost me a few dollars for reading them at the dealer, turned out to be a bad battery causing it. So I wanted a code reader that could delete them as well, so I ordered a Kiwi wifi II (
www.kiwiwifi.com) and in order to use it you must download an App, in which I chose the Dashcommand App. (
http://www.palmerperformance.com) Once I downloaded the App and explored the other functions that come with Dashcommand I found that the App had video out capabilities and displayed the iPhone screen on my NAV. Soooo, I started exploring the PLX modules and ended up installing a Boast, EGT, and a couple of fluid temperature and a pressure sensor modules.
http://www.dashxl.net/dashboard.php?dashboard=557
All of the gauges you see with the last link,
http://www.dashxl.net/dashboard.php?dashboard=557, are fully operational and was designed specifically for me. I elected to have the "Skins" downloadable to anybody who wanted to use them. It cost me a few dollars to have developed, but I think its worth allowing anyone to download them. I spent a $1000.00 after it was all complete, but keep in mind what a quality Gauge Set and Code Reader would cost, and with 6 gauges where would you put them all. The NAV screen is my gauge pod, so I don't have gauges all over my dash and in my way.
BTW, if you purchase a Lockpick, buy it from the developer. I had a couple of issues when installing it and the first question from the developer, was "where did I purchase it". They had to send me two different lockpicks to get it to work, and several sessions with the tech on the phone. If I had purchased it from a second party, I would have not gotten the support I needed. I have an airbag warning light pop up from time to time for a second or two, but it does not effect the operation of the airbag, (per my Dodge tech), and I ignore it.
