Is there a way of installing a cable pull throttle lock on linkage. Had one on a big truck and used is as a make shift cruise control on the road and could do the same thing that your looking at to raise the RPM a little so oil and fuel would be raised also at warn up
this kinda looks good. cheap and 2 seconds to install. no wiring no mounting. pull it out and throw it on the back seat
The first gen trucks had a hand throttle... fast idle was achieved by: (1) use pedal to raise engine speed to 1200RPM, (2) pull & rotate throttle handle, (3) release pedal... granted, that collection of parts is likely no longer available from dealer, but that is what junkyards are for... plus, it keeps the truck interior sanitarily-Dodge (my overarching-goal).
the cable is entirely within the cab, serves to keep pedal from fully-returning to idle...
Walt K.
I think you are correct about why it was discontinued... but doesn't seem too desirable to use as a "poor-man's-cruise-control" as in un-modified (un-molested?) form it held 1100RPM only... .I think folks using it as a crude cruise control caused that to go away...
But, as I recall the cable simply through the top of the fuel pedal rocker just above the throttle cable connection. That might be an option on a 2nd gen if there is material enough there.
Will have a look next time I service the old girl.
Mike.![]()
