anybody else heard of the "wobbleplate" motor?
2 really neat websites
Dixon 0 turn mower
it's really a neat idea...
5 pistons arranged in a circle parallel to the "crankshaft" (ie: the pistons move back and fort in the same direction the crank shaft is "pointing"). At the end of the crankshaft is the "wobbleplate" which is a big circular disc. The crankshaft passes thru the center of the disc, but the disc is not perpindicular to the crank, it's at an angle other than 90 degrees, so that as the crank turns, the plate "wobbles" (kind of like a bent rim. The piston rods connect to the edge of the disc via u-shaped connectors, kind of like grabbing the edge of a plate with your hand and holding the plate so you are looking directly at it. As the crank turns and the plate wobbles, the pistons move back and forth because the end of the connecting rod (which slides along the plate on rollers) must move back and forth as the plate wobbles. What's really neat is that you can change the compression ratio OR displacement on the fly. Change the compression ratio by sliding the crank back and forth and change the displacementt by changing the angle of the wobble plate.
ps. . the "head" is at the piston end of the engine (with the crank resting in the center) and the plate is at the other end.
They've built 5 prototypes so far, 3 or 4 have been 2 stroke and 1 is a DIESEL. Just thank, that durawhatzit pulls up next to you, just turn a knob and turn that 5. 9 into a 9. 5... hehehe
here's a link to the project site http://www.axial.co.nz/advantages.htm
'01 Eth 3500 4x4, Amsoil air filter, AutoMeter boost & egt on pillar mount. See My Truck and also be sure to read What tools & methods to use for an easy 1st oil change!!!
"Be happy you don't get all the government you pay for. " -W. C. Fields
[This message has been edited by dmurdock (edited 04-13-2001). ]
Interesting to note: the new Honda ATV automatic transmission is a wobble plate design. Clever adaptation of the concept. Almost no moving parts. The wobble plate pumps the fluid and forces the driven element to rotate.
Ron
Don't have to go nearly that far to see that technology. Go to http://www.dynacam.com to see a US made product. This design has been used in torpedos because of their favorable shape. They're certified aircraft engines and have been flown, although no manufacturer has chosen to use them in production. Another diesel aircraft engine is made by Zoche diesel out of Germany; they've had their radial air-cooled prototypes at Oshkosh for years and claim to have mucho testing time on them, although they are not in active production yet.
Tom
Tom Glover - VE7DQ, C-GWTG
99 QC SLT, LWB 4x2, ETC/DGP, Wht/Agate, etc.
If it is what I think it is, the same concept has been used in hydraulic motors and pumps for a long time. Neat application of the technology. Especially the part of turning a 5. 9 into a 9. 5. Sounds like a perfect partner to the VGT. Am I correct in this mental image?
'99 2500 ISB QC SLT (No Leather!), 4x4, 5sp w/McLeod, 4:10, BD-II, PE, PE-EZ, 4"exh. , Pac-Brake, A-Pillar gauge pod w/boost and pyro, Line-X, V-1, lights, siren, lic. plt. frame says "Diesel Fumes Make Me Horny!", and much more goofy stuff.
Yep, I have, Torpedo Propulsion Motors are Like that, They run on a Compressed Fuel. Also there is a Company in wash State that Makes a Lot Motor actuated Valve Called "Western Motor", They supply the USN with these Motor Operators for Valve's. Their motors are of a Nuetating type(sp?). It Consist's of 2 Geared plate's,(One of the Plates has 1 more tooth on the gear than the other) A Upper and A Lower. On the Plate are Magnets that are actuated by Micro switches. One of the Plates also "wobble", This give the Drive effect. And it Produce's a lot of torque, If the Microswitch's are not set up right,The motor will twist the valve in half.
Doug.
Didn't the old GM/Frigidaire A-6 compressor have a similiar design? Think they called it a "swashplate".
Bill Lins Wharton, TX 98 2500 QC SLT,12 (the CORRECT # of)valves,NV4500,3. 54 LSD,Manik grille guard,Semi-Psychotty Air,Amsoil everywhere, Reading aluminum utility body and bumper,Optima yellow tops- silencer ring & muffler stolen.
