anybody have pic's of an 04 w/2" leveling kit with stock tires?
The Sunroof option is no longer available
Exhaust in cab.
Just wanted to see what it will look like. I've seen them on trucks with bigger than p265's. I would like to see with normal tires.
Upload Errors
101_0138. JPG:
File Too Large. Limit for this filetype is 109. 4 KB. Your file is 1. 28 MB.
I got this setup. PM me and I can email you the pic
has anyone figured out how to do the 2" lift without moving the front tires back about 1" to 1 1/2"? I did my 2001 and 2002 but didn't like the wheel not centered in the wheel well
I think this looks good on these trucks, but am concerned about some of the issues I've seen mentioned.
1) Wheel sits farther back. Looks as though you would need longer arms to keep the wheel in it's "stock" location.
2) Vibration concerns. I have read about several people that have had issues with steering vibration after installing a front end lift like this... :confused:
#3, the entire front axle moves to the side 3/4 (left?) of an inch due to the track bar becoming more vertical
Well since the picture above I have added shocks, steering stabilizer and BFG 315s and I do not have any problems. No vibrations, no usual bouncing, no rubbing, etc. I have not had any of the "death wobble" symptons referred in some posts. Rides smooth and straight up to 95mph. I like my current configuration, seems just the right mix of height and tire size.
Just my 2 cents.
